error after execution "calibrate camera alignment" with lasercam and ortur LM 2 PRO S2
Good morning
I have a problem when I run “calibrate camera alignment”.
the cycle launches and stops when the “3” is burned with the following error:
Uart opened successfully.dev:/dev/ttyACM0,BaudRate:115200:8:0:1
ok
[ORIGIN: China]
[PRODUCER: ORTUR]
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master 2 Pro S2]
[OLF: 191]
[OLH: OLM_ESP_PRO_V1.2]
[SN: 3BF7694B570BDBFE1CE76B5C94798C20]
[OLM:GENERAL]
[DATE:15:05:32 - Mar 13 2023]
[VER:1.1f(ESP32).20210403:]
[OPT:VNMZHSL,35,7680,3]
Target buffer size found
ok
<Idle|MPos:0.000,0.000,0.000|Bf:35,7679|FS:0,0|Pn:P|CL:0,100|PS:2,1|ER:39,38|VA:25527,26|Ov:100,100,100|A:S>
ok
Starting stream
Stream completed in 0:00
Starting stream
Layer 100
Layer C00
Layer 100
Layer C00
Layer 100
Layer C00
Layer 100
Layer C00
error:1
G-code words consist of a letter and a value. Letter was not found.
On or near line 0:
Job halted
Stream completed in 0:28
error:24
Two G-code commands that both require the use of the XYZ axis words were detected in the block.
error:1
error:1
P1
Have you ever used this laser cutter with this computer successfully before?
Yes I did several tests with this computer.
All tests are successful
When you click on devices in your laser tab, what machine profile are you using? Plain GRBL or some variation?
Screenshot 2024-07-22 at 9.55.20 AM
When I click on the device:
PC to laser, we use GRBL-LPC
Pc to lasercam, we use GRBL GCODE as recommended in the lazercom Mintion documentation
I have exactly the same problem. Does anyone have any ideas what we could try to solve it?
After contacting the manufacturer, he did not have a solution to my problem.
I am returning this camera. :smiling_face_with_tear:
To anyone getting an error:24 using a Mintion Lasercam: Try changing the Transfer mode from "Buffered to “Synchronous” in the “Edit > Device Settings”.
