Error after update
hello,
after the lastest update, iam getting this error:
  • this application has requested the run time terminate it in an unusual way.
i didnt installed new software in the computer,.
any one is getting this error and how did you solved.
thank you so much
When do you get this error? Are you doing anything specific, or is it just when you run LightBurn?
just running the lightburn.
Are you running the 32 bit or 64 bit version of LightBurn? (If so, have you tried the other version to see if that will work?)
iam using 32bit version, never had a problem.
i havent try 64 bit version
Try the 64 bit version and see if that works better - as long as you have a 32 bit computer and OS, it should.
i must download 64 bits version of lightburn and install?
I’m not sure I know of any other way to do it. :slight_smile:
:rofl:thank you
