Sorry I am new here. When I started today everything engraved perfectly. After about 4 practice pieces I started getting this error.
I am currently using ortur master 2
Alarm 3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended
Currently only cuts approximately half an image
It could be that your topic is too big, ie. the limit is exceeded while the machine is moving or you drive very fast and lose / exceed limits. - It’s just a guess, but if you drive very fast it is worth a try to reduce the speed.
If this is not the case with your setup, it is worth checking to see if you are losing signals due to electrical noise. Much has been written about grounding problems with this type of machine here on the forum.
