ALARM:9 Homing fail. Could not find limit switch within search distance. Defined as1.5* max_travel and 5* pull off on location phases. It keeps scrolling this error code. Plus it keeps scrolling NOTE: 12V low, lease input power. Can someone point me to the right help. Brand new Neje max3 laser and intstall of lightburn first connection to Gateway
laptop. Thank you Stewyscrewy
This sounds like your power supply is insufficient/dying. I would contact Neje/your retailer and arrange for a replacement. If you have a higher-current power supply available it’s likely worth trying, as long as it is compatible.
Thank you very much for taking time to answer and appreciate the information.
