Ok, once the ortur LM2 laser starts and lightburn loads, it does a home cycle. Now what i have been doing is clicking the little pin/flag on the left hand tool bar, then clicking where the center of my project is. Sometimes i move my project down to the bottom corner, and then click the pin/flag to travel there. Is this a correct method to use?
The reason i ask, Tonight, i got an error code 9 “gcode locked out from jog state” i have never had that happen.
i have done a search for that error and seen some good posts, my main concern is how im moving the laser head. I want to make sure that didnt cause an issue
EDIT: Just tested it again and it shutsoff, same error
Starting stream
Layer C00
Layer C02 Pass 1 of 8
Layer C02 Pass 2 of 8
Layer C02 Pass 3 of 8
[BMA250:Shock and Movement detected! (292)]
Ortur Laser Master 2 Ready!
OLF 139.
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
error:9
G-code locked out during alarm or jog state.
On or near line 0:
Job halted
Stream completed in 20:08
i then closed lightburn, turned off the engraving portion (since that was complete and it stops on the circle cutting portion, moved the laser module to the place it needed to be, and just ran the cutting option and 5 seconds later it stops. the table was not bumped at all. it has been working fine all night and then this particular file… it doesnt like..
tried to do $262=0 and it says error 3 “command not recognized”
Its only on the circle cutting portion. the engraving does fine, but cutting circles on this particular file, it doesnt like. It worked earlier for another engrave and circle..
this is crazy haha
thanks
