Hi All,
I have created a very basic file with a qrcode generated by Lightburn\Tools\Create QR Code.
The output data stream viewed on the console tab keeps showing the below after approximately 40% burn completed.
X1.6S0
X1.6S300
error:25
A G-code word was repeated in the block.
On or near line 1107:
Job halted
Stream completed in 0:08
ok
ok
ok
ok
If I save the export the gcode and look all around this line number, everything looks ok.
I have tried multiple computers Win10 32Gb ram etc. Do difference.
If I duplicate the barcode, and print both at once, it works fine.
I have a K40 with a VMS LX4s (latest firmware) and this happens on Lightburn 1.2.0.0 as well as 1.2.0.1 (latest)
Running at 50mm/s and a line interval of 0.2mm still has the same result.
If I change the transfer mode from Buffered to Synchronous, I do not have the issue.
Thoughts?
