Error: Gcode word repeated and engraving a line through my project before stopping
This means the connection has been reset and LB initiates a new connection to the laser. Since the laser does not report a version string that is recognized, it gives this warning. This can be ignored usually.
This should not be related to your issue; I suspect this was just luck.
grbl-m3 is a device type, not an option. You need to change the laser type to grbl-m3. But this is most likely incorrect, since grbl-m3 is only for firmwares that are older than 6-7 years, which is not the case. Your firmware is much newer.
Constant Power Mode on:
Fails: 8
Successes: 0
Constant Power Mode off:
Fails: 0
Successes: 6
Luck? Maybe but pretty unlikely at this point. I have no idea why this would be causing my issues but I haven’t had a failure with CPM off yet.
I have contacted my laser manufacturer Atomstack about it and will update anything I learn.
This suggests an overheat problem, but does not tell us if it is the laser module, machine controller, or the power supply. It could even be a faulty connector that is heating up.
