Error in Light Burn Program
I get this error when I try to Frame:
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
ok
Ortur Laser Master 2 Pro S2 Ready!
OLF:OLF 185.
OLH:OLM_ESP_PRO_V1.2.
OLM: GENERAL.
[MSG: Flame detector Inactive. Luminosity too high]
Grbl 1.1f [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
What is wrong? I tried reloading the Default Program, but no change. This all started when I had set-up Rotary Tool.
3 things:
  1. Make sure that rotary has been disabled in LightBurn
  2. Update your firmware
  3. Once firmware is updated, reset to defaults using $RST=* in Console.
Also, check your starting position.
Thanks. I forgot to Disable the Rotary.
