Buenas noches. Cuando intento tomar la tecla MACRO de lightburn me sale el siguiente error, alguien sabe a que se debe? Gracias
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
That is just a status report from the controller. Are you having a specific problem?
Si, puedo mover el laser sin problemas manualmente desde el programa, desde la pestaña mover, pero cuando ingreso una imagen o algo para grabar y toco macro o marco, o directamente le doy iniciar me hace un pitido y el laser solo se mueve unos milimetros y no hace mas nada.
Yes, I can move the laser manually without any problems from the program, from the move tab, but when I enter an image or something to record and I touch macro or frame, or I directly press start, it makes a beep and the laser only moves a few millimeters and does nothing else.
This is usually caused by the laser being told to move beyond its physical limits.
Have you examined it in the Preview window? There will be a green fine line box (you may have to zoom out) with your part inside it. Turn on Show Traversal Moves and you may see those red lines going outside that green box.
Si, lo verifique pero todo esta en su lugar
Can you upload your Lightburn program that has the problem?
