This error message pops up after every burn. The burn completes but the laser stops at the place of the last burn spot. Windows 10 Ortur Laser Master 2. Thank you in advance.
The error message is as it states, meaning that the controller believes you’ve asked it to send the laser to something beyond the known border of the laser. If this is not actually the case it’s likely because the controller has lost its position.
What “Start from” mode are you using in Laser window? Also, are you ever manually moving the laser head by hand after it has gone through homing? If so, the controller will not be able to have accounted for those movements.
Please take a full screenshot of LightBurn with a design in place where this error would occur?
