I am getting a message that says, “Machine protected. Work paused.”
More than likely, one of the protection switches were activated. There are generally two, one on the door and one that detects coolant flow.
You should figure out which it is and fix it before proceeding.
If you ‘esc’ out and press the z/u button there is a diagnostic screen that will show you the state of these sensors.
That is specifically the door lid interlock “DPROT” pin. It needs to be pulled low (grounded) to enable running, I don’t recall if machine config can invert it, but you can disable it in config (or physically jump it to ground). Don’t disable it except for testing, you need an interlock.
