Hello. I’ve been working with my new 10W Diode machine for a few weeks now, and this is the first software issue I’ve had. I have run material tests, cut tests, engraved, cut out shapes with no problem until today (12/22/2024). Today, I successfully ran a material test, but when I tried to run a 2nd one, and I ran the Frame function, the gantry moved towards the working area, but then stopped and I observed the following error code: E (26) efuse: Range of data does not match the coding scheme
I’ve power cycled the machine and restarted my windows PC several times, but the error is persistent. I can run a prior engraving file, no issue, but the Lightburn Material test function fails with the same error message. It fails whether I run the Frame function, or run the Material test.
The error recurs with my Acer notebook running Windows 10 and my HP Notebook running Windows 11.
Machine: Lasertree LT-K1 MINI, 10W Diode
Controller: GRBL, but not sure how to obtain the firmware version. I found this article, but I don’t see the firmware version? Machine Settings - LightBurn Documentation
Lightburn version: 1.7.04, recently upgraded from 1.7.03. Paid license.
I even uninstalled 1.7.04 and reinstalled 1.7.03, but the error persists.
Thanks for any advice.
Jeff
Not sure if this is a GRBL Error 26 or not. Assuming it is, it is saying a GCode command was issued with no X, Y, or Z info. That is pretty strange
This implies there is something wrong in the code generated for the Material Test. A Windows update might have messes with one of the Lightburn files.
Download a fresh copy of the Lightburn installer file. Reboot the machine, and reinstall Lightburn.
If that does not work, do a Save GCode to a .NC file in the Material Test using the same settings you have when it fails. Upload that file here so others might inspect it.
Thank you Mike! Much appreciated.
What I did:
- Removed Lightburn
- Downloaded fresh copy of Lightburn
- Restarted PC
- Installed Lightburn (1.7.04)
- loaded prior engraving file to confirm it still worked, but when clicked frame, it failed. Attaching file “2024-12-23_01 kickit prior file fail code.gc”
- Opened Material Test, default engraving test for diode laser, clicked frame, failed. Attaching file “2024-12-23_02 kickit matl test fail.gc”
If this is going to be hard, I’m still within the Amazon holiday return window.
Update: Oh, when I say ‘failed’, the gantry moves about 3 to 4 inches, then freezes.
Thanks again and Happy Holidays.
Jeff
2024-12-23_01 kickit prior file fail code.gc (106.7 KB)
2024-12-23_02 kickit matl test fail.gc (300.3 KB)
If we cannot figure out what that error message is really telling us, it can be.
You uploaded 2 failed GCode files. I was hoping for one bad and one good so we can compare the GCode instructions. I reviewed one of the files and say nothing wonky.
Try this…
1 Enter $# in the console window. Look at the G54 line. It should be all zeroes.
2. if it is not, enter $RST=# in the Console window and retest. This will erase the G54-G59 and G20/G30 workspace offsets.
3. If it is all zeroes, Amazon is your best friend.
I can make a suggestion on a replacement, but I so not know your needs and budget.
Thanks Mike! I decided to go the Amazon return route.
I picked up a 10W Atomstack unit based on the good reviews and the fact that I could buy an extended service plan.
Thanks again. Have a wonderful 2025 and I hope next time I post it will be to have something fun to report.
Cheers.
Jeff
