I have a new controller for my system and after installing it and trying to use the move buttons, I get the following error. “you have entered a zero move distance”. The controller brand is YIDOFENG. Also, if I open an old project and try to frame it, the system runs to the end of the machine and jams.
Did you also:
- Set axis directions
- Configure homing
- Calibrate the axis step/mm
- Set axis speeds & accelerations
- Set laser mode & “spindle” speeds
Those are GRBL parameters that must be set up before LightBurn can control the machine.
Reviewing the GRBL guide may be helpful:
The LightBurn config guide may also be useful:
You can access all the config options through LightBurn’s Machine Settings, which may be easier than hammering them out through the console.
