Estimation time is not optomized
24in clock.lbrn2 (20.0 KB)
In the above file I am making a 24 inch clock. If I put the “burnable” area into a single layer, fill individually it says a burn time of 10:54 for my machine. If I change each to a different layer and sequence them myself, it estimates in 4:42 (using preveiw). Is there any way that I can improve the design so I don’t have to manually set the layers? 12 groups does not make sense to me either…
Probably the simplest thing to do is to change your layer to “Fill shapes Individually” This would fill each shape on it’s own, and not everything all at once. All in one layer, and it should do what you want:
