Etched Rock Sidehustle (an expanding how-to)
Now let me be clear, I got my first diode laser in February of this year '23. So it might seem like i am new to all this. However I was volunteer number two at a scale structure model company called Imagine That Laser Art. Up until the company sold. Serendipitously the company sold and moved to London area from Windsor of Ontario Canada, at the same time I did. I always tried to get back into the company but it was turned into a family business, which is something I can respect.
So I set out to buy my own laser to make my model railroad structure kits. Having the bug set, I was determined to buy a laser. That’s before diode lasers came out.
Long story short, one day my son woke up before me and started engraving a rock. Took him a few hours of testing while I wasn’t around. Suffice to say he stumbled on a side hustle we have been swamped with since the first week of May.
First post is the intro, Ill be reserving post 2 for settings and techniques for different rocks.
Photos of my Boss and our O scale version of Ebbett’s Field. Funny story tied to this model. I might share it in the future.
images (1)
Reserved Post for more info.
First Example is our Midjourney Rock designed by AI
I’m sure there is a formula we can come up with to translate diode power to CO2.
I use a first run as a 2 pass outline at 50mm/m and 100% power. Followed by a cross-hatched fill engrave. In move settings in lightburn I double the power and change line intervals to .3 for first run at 200 speed 100% power.
This was made with my 22w Falcon two with the fire lens on bottom of laser taped over. This laser is used only for Rocks. No wood as it would be a fire hazard to keep the tape on.
I too, have done a stone or two… but I’m going to wait until I have a Fiber Laser to do any more. Just seems too heavy a task for my CO2.
This look great!
I’ll be adding all this to my post and please feel free to add the settings you experimented with. I’m sure there is a formula we can come up with to translate diode power to CO2.
is there a way to edit a post here ?
Has to be your post… but yeah, look for this, and select the pencil:
Edit one.
Edit two.
Edit four… Nope. Works every time.
Weird i dont have it.
Try clicking the ellipsis (3-dots) icon. Does the pencil icon become available after doing so?
Nope, I think the post is restricted to one edit.
Screenshot 2023-10-31 141250
I think it was your account trust level that may have prevented you from editing. I’ve updated you to a “member” level. Can you see if the edit pencil is now available?
I think @berainlb is right. I edited, and closed, my post multiple times.
I noticed you are on a phone and I am on the web interface… but that shouldn’t matter.
My chrome browser on windows 11 can’t.
I just copy and pasted on my android and it’s fine. Weird bug somewhere
Lets think about this for a minute — lasers do not fire a constant beam, lasers fire in pulses, firing for a fraction of a second at a time and a whole lot of times per second. The longer the firing time, the hotter the beam, (temp wise) and that determines weather your etching or cutting. ( % of power is really a measurement of time) Lets say you are running a 120w. laser. No matter co2 or fiber. I am running a 20w. diode and I’m etching sandstone at 14% power. 20w x .14% = 2.8w. So you need 2.8 w power to burn/etch my stone. So 2.8 w. of 120w = power setting of 2.333% Now you can burn my stone at the same power as I do. ( I think I got all this right?) And to make you feel better, nothing to it !! GO FOR IT !! ( I don’t know if your laser will turn down that low, I have read on here that some big lasers won’t turn down that low)
Randy – good Luck !
