Im cutting some material to sew together and have cut a few trial pieces. Rather than drawing individual slots/cutting holes, I’m using perforation mode with a line to cut my sewing holes. However i’m finding it difficult to get the perforations to cut equally on both sides. As they just continue on there set size tracks.
I have changed the layers assuming if i make 1 line blue it will start the perforation and making the side which needs to be sewed to it red, so i was trying to get the red line perforation starting at the same point so the two pieces perfectly line up.
This isn’t the case. they are offset and basically “opposite” to each other, so they don’t mesh at all.
Any suggestions on how to get the perforations to match identically or should i manually draw each cut mark on. Be a HUGE time saver if there’s a way with perforation mode
Ah yes i see your point, i changed it to cut all in the same direction, but even the example shows it will be offset, when the artwork is even. I realise its due to the perforation mode.
Ah ha… i think your brillance has solved my problem…
i just had a tinker around with the optimised path setttings and it seems set in a certain way they become even.
Also cheers i never knew about the START LOCATION arrow button, ive still got alot to learn about LB!
