I made an excel sheet , but I can not use it with lightburn. The lines appear, but the text does not appear. In what file format should i transform the excel file to have a good definition on Lightburn ?
Thanks for your answer
Plain old CSV is what you need:
LightBurn does not handle exotic variations of Comma Separated Value format, so you may need to experiment with Excel’s export options to produce the simplest possible output file.
Could you provide some more information? What you’ve tried, some screenshots, a sample Excel file and what you want to achieve would be very useful.
My first thought is to go via PDF but without any of the information mentioned it’s hard to say.
