I recently purchased the 40w laser module for my D1-Pro. I am having difficulty with the movement of the module. It now moves very quickly during engraving, causing excessive vibration that affects the quality of the engraving. Is there a setting where this movement can be adjusted?
If the manufacturer allows you to change the GRBL parameters, you can reduce the value of $120 and $121. These control the acceleration rates. Lower numbers reduce the lurch when starting a motion.
- BE SURE you record the values before changing them.
- Use the Lightburn Machine Settings window to change them. To see the rest of them, double click on the Outputs Setup bar.
- Use the Save to File button. See #1 above.
- Resist the urge to change something to see what it does.
EDIT: If the laser frame was not designed for the mass of a 40w laser module, you may never be able to remove vibration entirely.
