Exhaust question
If my machine is not exhausting correctly and there is a considerable smoke buildup does that affect my laser cut quality and is there a way in lightburn to calibrate it? Also does the beam of my laser have to be hitting the lens at the exact middle or just hitting the correct surface of it ?
If you have an inefficient exhaust, your optical system will look like the rest of the machine, typically like a red-yellow, sticky surface - so yes, exhaust does affect the laser effect.
Inspect your mirrors and lens, clean them and align the laser beam so that it hits 100% of the center of them. Without that, you can’t expect the machine to run properly.
PS. a proper exhaust also ensures that your lungs don’t look like your machine surface :wink:
Normally it is an external or machine-specific part of your laser. You install an extraction system and start it together with the machine or when you use the laser function itself. If you have an “automatic” control of your extraction, you can decide in the layer window from LightBurn whether to extract or not.
Follow @bernd.dk’s advice to clean the mirrors and focus lens, then use a lint-free cleaning stick with isopropyl alcohol to clean the dirt off the laser tube’s exit face inside the water cooling cap.
The exit faces Mirror 1 with very little clearance, but it’s just as dirty in there as everywhere else:
