Export as legacy dxf v2.1.02 corrupts drawing
I have a case of a drawing appearing corrupted upon ‘Import’ after having ‘Export’ as legacy dxf format. I believe the problem to be with LB Export of legacy dxf format, not Import. Not all LB drawings exhibit the problem, thus far only this one, but I have not tried to debug or isolate the cause.
I noticed the corruption, which appears to a lessor extent of that shown below, when importing the legacy dxf file into Sheetcam. So I tried ‘Importing’ back into LB just for grins and found even more corruption of the drawing. Thus it seems there is something amiss with LB’s legacy dxf Export format. I did not notice any corruption ever in previous versions of LB, but I can’t confirm this drawing specifically as I recently edited it in LB v2.1.02 and specifically adding the text which is showing corrupted.
I would use the ‘modern’ dxf Export format except that it is not compatible with other CAM software that I use.
Here is the corrupted drawing as imported by LB…
p- new material test cut.dxflegacy.dxf (176.8 KB)
Here is the actual/correct drawing in LB as the .lbrn2 file…
p- new material test cut.lbrn2 (82.7 KB)
There’s more info just discovered…
There may be drawing corruption with LB Export ‘modern’ dxf format also, but only observed by Sheetcam import, not observed by LB import.
Here is the Sheetcam drawing view of both versions of dxf, top drawing is imported as LB Exported ‘modern’ dxf format, vs. bottom drawing is imported as LB Exported ‘legacy’ dxf format…
Arrows denote corrupted drawing features.
p- new material test cut.dxfmodern.dxf (193.0 KB)
Hi Lou,
The same tested here with dxf legacy and Lightburn.
However I tested all formats with Corel Tech2024 and the SVG gets the outer shape filled and the .ai becomes bold…
definitely something strange with the exports.
