Help me find a solution, please. How can I export a file to ai. / dxf. with bridges / tabs saved. When I export, the bridges disappear. Is this even possible? I found your answer.
"Yes, you can set the tabs as you’d like, then with the shape selected,
Go to: ‘Edit’→’Convert to Cut (debug)’ to bake the tabs into a copy of that shape
With that new shape selected, then go to ‘File’->‘Export’->‘Save as SVG’ "
But I don’t have this button in the edit tab .Thanks
Convert to Cut will result in the “cut” shapes overlaying the original. Make sure you’re not dealing with 2 sets of shapes. The “cut” debug shapes should reflect the incorporated tabs.
