I recently installed LightBurn, I really like it and I intend to buy it soon. I got a problem when LightBurn I run the export macro in Corel, the program starts up and works fine. But if I try to send new data to the program when LightBurn is open, it says “Project not found” “The file C: \ Users \ ??? \ LBExport.ai could not be found”. Could this be due to the fact that my username consists of a cyrillic? And if so, how can I fix it without changing the username? Thanks in advance for your help!
P.S.
I searched for answers on the forum but couldn’t find it. One answer had a link to a file from google drive, but it is 404 now. I wanted to try this. I am using Win10 64 PC
Thanks a lot, I thought in this direction. I’m not very good at programming, but I understand what you are talking about. I will try to take your advice. Apparently the whole point is that the program does not understand the Russian encoding … I think Oz could fix this so that other users with the Cyrillic would not have problems. Thanks again for the advice
There’s a chance this has been fixed already, as I’ve fixed the encoding for a couple other things, but it might be that the SendUDP tool used to trigger the LightBurn launch isn’t handling the extra characters properly. I’ll have a look, but your solution is completely fine too.
