hello im wondering if there is someone out there who has encounted a problem running the exported g code file with a genmitsu wifi module and android tablet.
The file exports to a gc file which i transfer to my tablet but when i try to load it into the genmitsu app i keep a error and a failure to load the file to the app.
i am very new to millmage and i am currently running a trial licence but i have enjoyed the interface i just wish i could figure out the export issue.
i have used easel and carbide create in the past and they exported nc files i don’t know it might be the wrong format i have tried to find a way to change to a nc file but i havent succeeded to export a file that works with my setup
Try it using a USB connection instead of WiFi. Or try it with Candle or GCode Sender. I am guessing the issue is not in the file, but in the transfer method.
I have a Genmitsu machine and it runs MillMage GCode without issue.
That suggestion worked great i just needed someone to tell me .
I typed nc into extension and switched the tab to single file.
the file is now a nc output and works with my wifi module .
Thank you for the help i appriciate it greatly
