Extend Laser position time out
Is there a way to increase the laser position time it stays active? It seams to cancel itself right before I click. Example: I click a location I want to verify, go over to the machine and check laser head position, return to lightburn when laser position button is still active, but then sometimes it deactivates before I click the next location I want to verify…
It remains active for approximately 15 secs. Is the a way to increase this to 30 secs?
This is interesting. Does anything appear in the Console window in LightBurn that coincides with the Laser Button deactivating?
Please check to see if this is related to the Network Timeout setting in Device Settings. Mine is set to 5000 ms which is 5 seconds.
Nothing appears in the console window when the laser position button turns off. It just activates the pointer.
My network timeout is also at 5000ms or 5 secs but this issue should have nothing to do with the network.
Before this topic gets automatically closed, any admins have any ideas?
If I understand correctly, he’s referring to the Set Laser Position tool, which has a hard 15 second timeout:
