Factory Reset - Ruida
We gave to Def factory para this code HF8888 then machine frame work opposite could someone tell how to restore Def factory para setting
Uploading: 20210522_18115.jpg…
@Afghan1, your image did not load because you did not allow it to fully upload prior to committing the post. You can try again.
As for the Factory Defaults for your system, you should be able to get these settings from the supplier directly. They are the folks that set this up initially and should have the correct configuration setting for you.
If you need to start anew, have a read here for some help: Configuring A Ruida - LightBurn Software Documentation
You also need to update your forum profile to include information about your laser machine.
Filling out your profile with your Machine Details:
When you sign up for the account on the forum, there should be a field to fill out what Machines you have. Please make sure you have this filled out and it is accurate with your Machines you have, and what Controllers and Firmware they run.
You can edit this by clicking on your profile icon in the top right (on desktop browser), clicking the gear icon in the menu that pops up, and going to the Profile tab.
