Fake preview vs engraving
You are probably right. I am just now running a test without a point correction. I think this may be the problem.
10:06 AM
I finished the test and the defect has been corrected. Probably having spot correction turned on caused some spots to be so small that the Gcode does not appear and the laser simply did not activate in those areas.
I did the test with the dot correction turned on but a lower value than before. To say, that the point correction had a value very close to the line interval, now I set exactly half of the line interval and the result is quite acceptable.
Thank you all for your help.
