Hey guys, I’m kind of lost here. I spent 5 hours straight trying to fix my problem with the Falcon 2. I just received it today, but when I try to engrave or cut, it stops suddenly with no warning or signals. I’ve tried everything - switching to a different wall socket, using a different computer - but nothing seems to help. Strangely, when I saved the G-code to an SD card and ran it from there, it worked perfectly fine.
What could be causing this issue? Also, can someone explain why the beep sounds are so loud? A neighbor actually called the house caretaker because she thought there was a fire alarm going off, when in reality it was just the loud beeping from the Falcon 2.
I would really appreciate any help or suggestions you may have. I’m eager to start creating some fantastic projects!
