Falcon 2 Pro Camera Calibration Suggestions
Has anyone setup the camera on a Falcon 2 Pro with lightburn and had success? I’ve only gotten one calibration to go through and ended up 10+mm off on both axis. I know this is a fiddly process but was curious if anyone had any tips for getting the best results? What size did you print your calibration pattern? Did you print or engrave it? Did you augment the lighting in any way? Did you push the test pattern against every edge of the machine or did you try to keep it inside the work area?
For it worked fine. I used the standard process, did nothing special. I used all defaults.
If you have a deviation, the best way is to do the calibration again. It might take a few times.
Be aware that you may not change the height of the workpiece after calibration.
Some additional info: Using a camera with a diode laser - Diode Laser Wiki
