Falcon 2 Pro not framing
Just un boxed my new laser, Having issues with the laser homing, but when framing a job it wants to go out of bounds. I’m unable to do any test cuts.
LB is picking up, and auto set up the device.
I’m not sure if this is related, but I’m also unable to connect the machine in laser grbl
Thanks
You mentioned homing problem. What is it doing? If homing isn’t working properly, nothing else will.
Next, switch from current position to absolute coordinates. That makes the Lightburn screen a direct representation of your workspace. If your graphic is within the work grid it should frame properly.
To see laser when framing you have to enable the following switches and set laser on power to 1%:
Did you create your device by importing a .lbdev device file?
Creality Falcon 2 Pro.lbdev (2.5 KB)
when homing, it crashes into the front left corner, to a point that there is audible belt slippage.
I have been able to do some tests after restarting multiple times. but the framing where I want it to frame is not happening.
I did not, the device was picked up by LB in the find my device window. I have also noticed that the COM port isn’t showing CH 340
like it does for my Masutar Pro. Is this part of the issue?
this isn’t exe. what am I supposed to do with this text???
Does this have limit switches? If it does one or both are either out of adjustment or nonfunctional. Verify that the laser head/gantry makes contact wit hthe limit switches.
Click the Devices button in the laser tab and click import. Select that file and it will install your machine with the correct info.
I was having the same issue. Now that stopped on it own. I need a lot of help. I have only had my creality falcon 2 for about two weeks. It was doing ok then all of the sudden it wouldn’t burn anything. Now I can’t get it to move out of home position.
If someone could help me, I would greatly appreciate it. Everything is a foreign language to me with all of this. Like I said I’m brand new to a laser
Let’s start by doing your best to describe what it is or isn’t doing and what you’ve tried with as much detail as possible. I’m going to sask for some screenshots. Please post a screenshot of your entire Lightburn screen with your project loaded and the Cuts/Layers Panel and Laser Panel visible. Also post a screenshot of the Settings Window (Gears icon) with the Units and Grids tab visible and post a screenshot of the Device Settings Window (Wrench and Screwdriver icon). In your Console window thpe $$ and press enter. Copy and paste the entire output of that window.
