Falcon A1 Pro + LightBurn 2.2: camera overlay scaled 8 to 11% too large despite successful lens calibration and alignment
Hi,
I’m having a positioning problem with the camera on my Creality Falcon A1 Pro in LightBurn 2.2 (Windows). The overlay shows everything larger than reality by a reproducible scale factor, even though the lens calibration and workspace alignment both report success.
Setup
  • Network camera, Overhead mount, 1440 × 1080, camera control not available in LightBurn.
  • The machine’s lights cannot be turned off (reflections on the material).
  • Test material: 7 mm corrugated cardboard (measured with calipers).
What I verified
  • The machine itself is accurate: an engraved 100 × 100 mm square measures exactly 100 mm. An image designed at 92.7 × 158 mm engraved at 92 × 159 mm (measured on the cardboard).
  • On the LightBurn overlay, a 100 mm square drawn in pencil, matched with an unrotated square, measures 108.55 mm. The same engraved image reads 103.5 × 175.2 mm on the overlay.
  • The error is a pure scale (nearly identical in X and Y, no visible distortion), between 8 and 11% depending on the attempt. It is small near the center and grows toward the edges.
What I tried
  • Lens calibration with the Standard model, then the Extended model (9 captures, 86% score) . After correction, straight lines on the table stay straight.
  • Automatic alignment (8 tags detected) with material height set to 7 mm, then 10 mm. The measured square goes from 108 to 110 mm: height has an effect, but far too small to explain the error.
  • Alignment with the tag pattern centered in the field of view. The error stays the same.
  • In Falcon Design Space, the same test gives a smaller but still present error (about ±5 mm).
My questions
  1. Has anyone seen this kind of scale error with the A1 Pro, and how did you solve it?
  2. Is there a scale or camera-height setting I might have missed?
  3. Does this network camera need any specific setting during calibration or alignment?
Thanks in advance.
