Falcon2 22w error 80 alarm 3
started having issues with my falcon2 22w. i can home but cant frame, move or start a project without it immediatly stopping and throwing the following
error:80
On or near line 1:
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
On or near line 1:
Job halted
heres what i have for settings
$0=10
$1=250
$2=0
$3=4
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=1
$22=1
$23=3
$24=2000.000
$25=4000.000
$26=20
$27=5.000
$30=1000.000
$31=0.000
$32=1
$100=80.000
$101=80.000
$110=25000.000
$111=8000.000
$120=500.000
$121=500.000
$130=294.000
$131=305.000
$150=4
$151=4
$152=30
$153=0
$154=0
$155=0
$156=1
$157=1
$160=1
$161=8.00
[G54:-nan,0.000,0.000]
[G55:-nan,0.000,0.000]
[G56:-nan,0.000,0.000]
[G57:-nan,0.000,0.000]
[G58:-nan,0.000,0.000]
[G59:-nan,0.000,0.000]
[G28:-nan,0.000,0.000]
[G30:-nan,0.000,0.000]
[G92:0.000,0.000,0.000]
[TLO:0.000]
[PRB:0.000,0.000,0.000:0]
If everything works except starting the job, the power supply most likely has died. Try to run the project at 0.1% power, if this succeeds, the power supply is dead.
reflashed laser head and board with updated firmware, got rid of error 80. still getting Alarm:3 when i attempt to start a job. even with the power dialed back to 0.01.
when i attept to frame the job i get this:
Starting stream
Stream completed in 0:00
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
this happens both on the rotary and on the flat bed. and with each the laser head moves a fraction before stopping.
A/c adapter seems to be fine
all connections seem to be solid
the usb cable is new with the ferrite on each end
Jim
I just did a search in previous topics for alarm 3 and most were caused by a bad usb cable.
You might find more info in Lightburn Doc’s alarm3 that will infor you more.
