Faserlaser: Adjust position while framing again does not work
Hello
since the last thread about that problem: Faserlaser: Adjust position while framing
it worked on version 1.7.07
But now 1.7.08 this necessary function does not work anymore.
Please fix this, thanks.
Ok, I reinstalled the v1.7.07 and first it still didn´t work. The job is a text which is applied to a circle. The circle output is disabled. If I now go to framing the faser moves the text with arrowkeys but not in the software. I first have to enable the output of the circle (path) and then can adjust the position while framing on the machine and the software. I swear before I installed the v1.7.08 it worked without the need to enable everything.
Are you sure? I discovered this the first time in 1.07.08, I did an Apply Path to Text when I was trying to get some circles out of the picture.
yes I am sure. It would not make sense to move the hardware witout moving the position in the software simultanously. If just the hardware moves, any try cut or setting does not affect to the moved position.
The path and text are stiched even if there is no output or view of the path, so there should be no need to first enable output or view of each.
