It would be realy helpfull to be able to fill the material size with stars for example and then mark the main Object you want to laser.
After that mark everything else and then delete everything inside or touching first selected element!
this way you could fast fill all wasted space to get something out of it!
Picture will make it more clear i guess
The Christmas tree is the main focus of this Project but i want to fill out the rest with stars
Deselect all inside or touching the Tree or even better mark everything touching or inside the tree to delete it!
Group all stars, duplicate the Christmas tree, select the Christmas tree and the stars, select “Boolean Assistant”, subtract A-B and you’re done.
I want to delete everything inside the tree + everything that is touching my tree lines!
So we have a fast way to fill all the empty parts of our material to get something out of it instead of having bigger strange shaped pieces all over the place!
no boolean works here
Thats why it says
Feature Request
with your way there are parts of cut off stars left noone needs! why would i let my laser cut out stuff i dont need and my laser will run out of life faster
But thank you your suggestions speed ups manual mode atleast a bit!
