Feature request/question?
ok this is a request / question i know you can set the number of passes but is there a way to set the power level per pass ?
This is where you need your feature requests :smile:
Can I ask why you want to? Because you can set a completely arbitrary number of passes, allowing you to set the cut power per-pass would mean a lot of additional UI for something that I can’t see being used often. If you’re trying to accomplish a high power / low power arrangement, you could just duplicate the graphic and run it again with the second layer having a different power setting than the first.
