Fogendes Problem. Beim Lasern von Text tritt diese Fehlermeldung auf. Was könnte das Problem sein?
Show your firmware settings and the laser window. Your laser is standing at a position where the output can’t be lasered without hitting the borders.
The problem is the language… Please use English, that helps a lot to understand the issue and maybe you find the answer easily in the documentation or this forum.
