Fehlermeldung der Software
You have not answered the question regarding whether you have objects outside your work area. (shift + layer)
That you have not received a response from other members of the forum may be related to people not knowing “Hobby Laser” try to elaborate a little more, is it a diode laser or a CO2 machine.
What is your work area, which Gerbil profile have you set, what does the $$ command in the console show? …
Another obstacle could be that you do not write in English, try to convert your text through Google Translate, otherwise everyone else will have to do your work.
I understand you’re a little disappointed, but your conclusion is definitely not right. Believe me, you will not find a better forum that deals with diode and CO2 laser machines and there is no program on the market that can compare with LightBurn.
Try to clarify your question and your information, use the forum’s search function and show some examples, then you will hopefully get a solution to the problem.
