Fern foiligree deep engrave on slide
Love that I am able to do jigging set ups…feels like I am back at dads shop playing around.
One of my neighbors around here approached me to engrave some of his pieces, so I am sacrificing my own as practice.
Jiggin this was fun…just a stack of magnets with a wide base.
80 total passes on a 20w fiber.
After 10 passes a cleanup pass was ran.
Approx .3mm depth
Looks great – 1911 slide lock?
What lens did you use and what are the other settings you used?
If you don’t mind.
Do you have an ffl? Just curious.
Yes sir a 1911 good eye.
I do not have an FFL but may look into it if I get into this too deep. Right now I wouldn’t plan on taking any whole weapons, rather single pieces at a time to engrave. I was just approached by my neighbor who’s an old marine and is heavy into this sorta thing.
Getting my settings now for ya
110mm lens, Gweike G2 20watt
Focused at 21mm from housing>work surface
As a Master Gunsmith I say Very nice job. I just bought my first laser engraver to do similar work on gun parts , if i can ever get the bugs worked out , i hope i can do beautiful work like that !
Rich
I’m gonna put up photos of my progress here of my full weapon detailing.
So far I’ve only used lightburn as the only tool for SVG manipulation (generation is Inkscape.)
I am really enjoying designing my own flourishes, it is an absolute blast. The improvements they have made to boolean operations is really really helpful. Have been using the heck out of the scissor tool as well.
.1911 .45 ACP Match Slide Front Tip Detail
1911 .45 ACP Match Slide Rear Grip Detail
1911 .45 ACP Match Slide Ejection (Right) Side, Mid Detail
1911 .45 ACP Match Right Side Progress Detail
I have reduced the total number of passes from 80 (+ cleaning passes) to 60, after chatting with @Mooseman684 a bit to ensure shell strength. This locks in the depth at approximately .2mm or 8 thousandths.
Man , That looks AWESOME ! The engraving looks deeper than .2mm and very clean. I sure hope I can master that with my Machine , I am a total Noob at this with my first Engraver and having never done CAD programming.
Rich
Let me know when you need help I’m glad to assist! I think the trickiest part for me was learning vectors at first. Then realizing that testing testing testing is important. :slight_smile:
Just the tip.
Slide top
Resolution test.
The width of this engraving is 5.3mm.
Font height is approx. 0.1mm and is legible under a better loupe…however, it seems the finish starts ablating in larger chunks and quality degrades.
Testing powdercoat fill and building courage to attempt slide
Comparison of blue relief block printers ink (blue) vs powder coat
In both the ink relief method and the powder coat fill method there is a sanding step. I am unsure how confident I am in sanding a contours surface such as the top of the slide, so I am stuck for now.
Powder coat harbor freight special does just fine.
I seem to be owing my wife a new toaster oven, so there’s that. Oh and I wasnt ever planning it for food ever again btw…but these things need to be communicated.
I’ve seen a couple people use the laser to bake the powder. Not sure if that will be any better than baking. But nice work!
For small item like that you can cure the Powder coating with a heat gun. You can see the plastic melting and getting shinny when it done :rofl:
Doesn’t adhere as well. The plastic melts from top down and sticks to itself, shrinking upwards. Oven is even heat. Also don’t have a heat gun, so we use what we have available.
