Thank you for the warnings about beryllium oxide — I really appreciate the safety advice.
To clarify, my material is just a very hard ceramic, 1.2 mm thick, not beryllium oxide. I’m looking for tips on laser settings, focusing, and example cutting paths for this type of safe ceramic material.
Any practical advice or example setups would be very helpful.
We can only work with what you tell us. Does anything else in your description need clarification?
That depends on what the raw part looks like and what it should become; to a large extent, you describe the geometry and LightBurn directs the laser beam along it.
For a simple straight cut, you draw a line, specify the power & speed &c, and LightBurn creates the commands to make that line happen. You’re responsible for setting up a suitable fixture to ensure the part is under the line.
IMO you have overconstrained requirements:
A specific fiber laser machine
A specific material
A specific thickness
A specific cut performance goal
The machine power determines the cut depth per pass on the material, so a through cut will need as many passes as it takes. If “the cutting is very weak”, that suggests the machine does not have enough power or your expectations are too high.
If you specify “3 passes” to cut through a specific thickness of a specific material, then you must choose the laser power (and speed, etc) to make that happen.
You’ve also specified EZCAD2, rather than LightBurn, which rules out much of the expertise you’ll find around here.
