Hi!
First of all, my Setup:
- No Name Fiber Laser with JCZFiber 2 Card
- CNI Laser FL-1064-6W Laser Source
- Lightburn v1.20.00 on MAC
Lightburn tells me the Laser is busy after clicking on Start – the Frame Function works without a Problem. I tried all 4 Laser Sources but unfortunately it doesn’t work.
Here my Lightburn Settings:
Thanks!
Elias
In EzCad, what is the laser source setting you use?
Lightburn is the first Software i used. I bought the Laser without EzCad. The build in Board is without a Dongle for EZ.
We use the EzCad setup information to configure LightBurn. I do not recognize your laser source, and I would need to see the EzCad settings used to control it in order to tell you if we can support it.
Ok i understand. I try to get hands on a Dongle.
Thanks
