Hello, good day, I hope you can help me when trying to pause the work using the rotary on my fiber laser, the program no longer responds to resume, I have to stop the work and reselect the port so that it responds again, I think it is a version problem. Since you have returned version 1.2.04 and it works perfectly, can you help me solve the problem? greetings!!
Following along. Couple days ago I happened to pause and restart on my fiber/ chuck rotary, ver 1.6.03 seemed to pause and start a couple times no problem that I remember. Did you try a re-boot before you downgraded to VER 1.2? Was it the exact same file both times? What exactly do you do when you “Reselect” the port?
Hola, gracias por responder, así es hice lo mismo con la versión 1.2 cero fallas , pero con la 1.6 simpre hace ese error
