Fiber laser rotary. Split size offset
LB has a rotary positive offset parameter for split size overlap. When running large split size, there is a positive overlap, or over shoot but I need a negative overlap offset.
Is there a solution since there is no way to enter a negative offset. I have had to play with acceleration and speed to try to minimize but still not enough.
Does LB have any plans to change this?
Can I pay for a custom feature?
Rob
Should I talk to LB direct to get answer to this?
