I am setting up my OmTech 30W with the JCZ motherboard. Do I need to install EZ Cad so I can import material settings or is there another way to get them?
Just setup EZCAD2 regardless of your LightBurn usage. You can easily swap between the two if you need to do that.
Does EZcad2 have a material library pre populated? I’ve been guessing with the settings.
Nope. Every laser is different. You have to figure out the in’s and out’s of your machine and build your own library. I’m sure you can find other people’s libraries and give it a shot if you want.
