I just downloaded Light Burn, Here are the sitting for my laser
Where do I put them in device settings?
When you create the device, it will prompt you for an EZCad configuration file…
If you use that, most if not all of these should be set…
The configuration file to import is the same one you used for EZCad2… markcfg7
Good luck
Thanks, I’ll give it a try
