Fiber Rotary for multiple items
Has anyone/how can I setup a rotary table with multiple parts for engraving with the ability to individually rotate each part to achieve 360deg marking?
I have seen the rotary tables for items that remain flat during table rotation but cannot locate a suitable option for also rotating each part.
I’m sorry if I’m not explaining this well enough, I would hope to achieve batch production with a fibre laser on cylindrical items.
TLDR; Is there a rotary within a rotary that works with LB?
how about this, in conjunction with a conveyor or rotary table to feed parts…
In the current release version of LightBurn (1.3.01) there is currently no rotary table support. Although, I will tell you that there have been some videos posted online from the developers showing Rotary Table support working in Beta code that will be released at some point in the future. So, it’s not hopeless, it is coming in the future.
Here is a home built rotary that uses a chuck pointing up… It’s kind of long and you can probably jump around in it…
