Any galvo you can get, that’s identified as a galvo by Lightburn, you’ll need the pro version. There are many grbl types with galvo, that are not identified by Lightburn as a galvo, so many of the galvo settings, such as 3d slice are not available except with a known galvo.
Most of the galvo machines were initially brought on-line with Lightburn, in v1.2, I believe, but there has been additions since then. Windows 10 has hit it’s end of life, there are no updates for it.
The pro version will run all supported platforms, including grbl.
I may not be the one to ask as I don’t own a UV machine. However I’ve done some research on them and I believe the way a UV works is mainly by using the high photon energy of 355nm to knock molecules apart. They refer to them as cold lasers, but I’ve seen them smoking. Better than most lasers from a heat standpoint, but I’d shy away from calling them cold.
You may have to engage in a different thought process to effectively use one, at least in my opinion. We normally don’t think about a laser eating it’s own optics, but the UV photon impact effects the whole optical path in one of these. I’ve seen some nice products, like my fiber, MTBF is about 100k hours, some of the UV machines only warrant up to 5k hours…?
I’ve watched people use these to cut out glass and put holes in glass. The minimal heat makes this possible. There is tons of information on UV lasers, you just have to spend the time to carouse them all.
You can probably cut acrylic, but it’s limited to a couple mm, these are mostly used to engrave fine lines, not deep types of materials. You can probably mark metals in some way, but a fiber is a better choice for this as these are really engravers, not cutters.
Most of these that are reasonable in price are 5W models, shorter wavelengths make generating the basic signal more troublesome that longer wavelength frequencies. Some use a fiber as source, but use it’s third harmonic. 1064nm / 3 = 354.666666667nm.
I have noticed that, although a 5W is around $5k, most of the 10W or over increase almost exponentially in price. Keep in mind there are less available settings with a UV.
Although from Cloudray, here’s the best comparison of price/power I’ve seen. Doesn’t mean I’ve seen them all.
Even with a discount of $1000, the 10W is still $2k more expensive. Most hobbyists can’t afford this increase in price for a doubling of power. Can you find them lower cost, probably.
In my limited research over the last year, it seems a liquid cooled system is recommended. As I mentioned the source is difficult to create and the temperature of the actual diode is very critical to maintaining power and emitted wavelength, water cooling helps maintain a more constant temperature.
There are many that are air cooled. Many of these I’ve seen recommend up to 45 minutes of warm up time. More likely is they want a stable temperature environment. The TR series like I have posted need ~5 minutes to stabilize.
There are people here that actually own one of these and I’d suggest you wait on one of them to advise you and add to your knowledge before taking the plunge.
Nicky (@Bulldog) has posted some of his 5W UV work here in the finished creations. Love to hear from him about this. There isn’t much doubt he has his own opinions about using one of these.
Have any questions that others or I may be able to help you with, sing out.
