File cuts with line but not fill
This file will run cut the line , but if I change to fill itt will not run and I get no error messages
Adam Durst label 1.lbrn2 (404.8 KB)
The file looks ok. I did not try and run it on my machine, but it works fine in preview, no reason to think there is an issue.
What exactly happens? Will not run is very little information for us to help you with this.
Hi Jack,
Thanks for your support
If I change to line it runs. When set to fill it previews but when hitting play I get a single beep and a message flashes on the screen but it is too quick to read.
Hope that helps
Michael
Is the beep from the Ruida and where did you see the error message. You need to find any error messages. Most software holds the message until you click on something.
USB or Ethernet?
The design seems to sit very close to the edge of the platform, so most likely the overscan region extends beyond the machine’s limit.
Move the design to the middle of the workspace to see if that improves the situation; using Absolute Coordinates will eliminate any issues with the other Start From modes:
