Ruida 6442G, firmware ends in .50
LB .8.07
Windows 10
Tested using both ethernet and direct USB cable for connection
When I run this file where all test lines are set to dot mode, it will cut partway through the first line and then stop + beep. The screen displays “File Invalid Please Pause” At this point, the controller is basically locked up. No keys on the keypad respond except for the Reset. If I press reset, once the reset is done, the file will run fine just once. When I try to run it again, it once again gives me the same error and behavior after cutting about halfway through the first line. If I change all lines so that dot mode is off, the file will run repeatedly without error.
I have attached the file. If anyone can please point out the error of my ways, I would appreciate it.
Thanks.
File Invalid Error 1.lbrn (10.1 KB)
