File naming on import
Hi all, I have noticed that when starting a new project, on importing a new picture the description/file in the cuts/layers is the same as the previous picture/job and not the one I am importing, is this a setting I missed? TIA Mark
If you’re importing a file, it is kept under the same name as the project…
If you import 10 pieces of art, you usually want the project name not to change…
If you want to change it, start with File → New…
You can open the original or import it. Open will associate a name, import will not.
Thanks for that, I see it is similar in that respect to my cad software at work. Thanks again :+1:
