I can’t find the file send button after I upgraded to 1.4.04
The ‘Send’ button should be found on the upper-right section of the ‘Laser’ window.
If that window was closed, go to ‘Window’→’Laser’ and ensure that is checked. To reset all windows, select ‘Window’→’Reset to Default Layout’.
Thank You so much for the help.
