Files exported to K40 Whisperer not filled properly
Files do not fill properly when I export to K40 Whisperer. The files start doing this after Lightburn Update to version 9.17. All the files exported before the update works properly, but if I upload the same file after the update, the are error on the filling.
hi, I have the same problem, have you solved it?
This appears to be a bug, though I will need to investigate why. I’ll look into it and report back when I have a fix.
No, I checked and nothing wrong with the file, look like is software issue.
I have been used the same file, in the same machine before, and everything is fine, until I updated Lightburn to the version 9.17 and 9.18. Other files has the same issues!!!
Has this been fixed? I cannot get my laser to do anything since downloading 9.18.
Exporting an SVG is not the same as running the laser. Can you elaborate on what you mean by “cant get my laser to do anything since 0.9.18?” I don’t understand how this would affect a laser running from LightBurn.
We do have a fix, we’re just testing a couple other things that were in progress to make sure they aren’t broken before we release again.
Home the machine and the x and y will only go one direction. The fire button fires full power even when set at .25. When framing it goes out of bounds instead of framing. Restarted and reloaded reset machine. Nothing seems to work
X-Carve machines are notorious for resetting “laser mode” ($32=1) and other settings. Do you have the ‘Use Laser’ macro that LightBurn sets up for you when you install?
Read through this too: https://lightburnsoftware.github.io/NewDocs/CommonGrblSetups.html
The above link talks about the settings changes needed to use LightBurn to drive an X-Carve or similar CNC machine.
